10-26-16, 09:28 AM | #1 |
Tips / Tricks for getting threaded pipe to seal?
I was helping out my father in law install an on demand water heater last night. The heater has 1/2" threaded pipe fittings coming out of it. So, we ran to the store and grabbed all the stuff we needed (valves, fittings, etc) and came back and installed it. We pressurized it and had a few leaks. So we removed it, tightened them up as much as we thought safe and reinstalled it. Still leaking. We used teflon tape on every joint and I'd say nearly half of them leaked. This seems ridiculous.
So, what tips do you guys have for getting threaded pipe connections not to leak?
10-26-16, 10:34 AM | #2 |
Steve Hull
Daox,
Don't feel bad . . . . Teflon pipe tape works great if the threads are in good shape. More recently, the quality of metal pipe threading has gone to hell. I never had leaks, in the past, but I get them regularly now if I just use teflon tape. I still use teflon tape on the outside threads, but now always use pipe "dope" on the inside threads. A bit more time, but NO leaks. Hope this helps. Steve ps pipe dope is messy and nasty . . .
02-06-17, 03:23 AM | #3 | |
The Following User Says Thank You to rclark762 For This Useful Post: | emilyhendrix (02-21-17) |
10-26-16, 12:02 PM | #4 |
What stevehull said. I don't rely on teflon tape anymore unless it's a tiny (ie 1/8" NPT or smaller) fitting.
The Following User Says Thank You to sunspot For This Useful Post: | Daox (10-26-16) |
10-26-16, 09:41 PM | #5 |
Thanks guys, I'll have to give that a try next time.
10-27-16, 05:27 AM | #7 |
Steve Hull
Randen - I have also used silicone based caulk (the kind that cures to rubber). Will keep your suggestion of 5 minute epoxy in mind also.
I guess we have all found that threading has gotten rather bad . . . . Steve
consulting on geothermal heating/cooling & rational energy use since 1990 Last edited by stevehull; 10-27-16 at 06:40 AM.. Reason: speling errors |
10-27-16, 08:11 AM | #8 |
Yeah, I did notice that while threading the pieces together it was not a nice smooth process. The joints felt 'gritty' for lack of a better word and didn't engage nice and smoothly.
01-11-17, 01:24 PM | #9 |
Land owner
Use hydraulic fracturing rated pipe dope. Since fracking uses preasures in excess of 9,000psi at the well head and something like 13,000 or 14,000psi at total deapth you know it will work.
I used it on my 7hp gasoline pressure washer which runs some where between 2,000 and 2,500psi on its pipe thread connections since 2008 and I don't think any have ever leaked. The only ones that leaked were the ones I used Teflon tape on. |
The Following User Says Thank You to oil pan 4 For This Useful Post: | Daox (01-12-17) |
01-12-17, 09:34 AM | #10 |
Where do you get said pipe dope?
