01-02-14, 04:24 PM | #1 |
Radiant barrier foil
A few months ago, I finally took the step to install some radiant barrier in my attic. Here in NorCal, summers go well above 95 degrees outside for a period of 2 months or so, with the sun beating down all day long, and the house gets incredibly hot - especially the second floor, of course (there's no AC). After stapling radiant barrier to the inside of the trusses only on the south facing side of the roof, max interior temperature on hot days is down as much as 8 degrees. The roll cost 100 bucks. If I had central AC, the barrier would probably have paid for itself in the first summer. As it stands, temperatures are much more comfortable with it. Anyone having heat problems, I can highly recommend this stuff!
The Following User Says Thank You to opiesche For This Useful Post: | brokejame (01-10-14) |
01-02-14, 07:25 PM | #2 | |
01-04-14, 03:48 PM | #3 |
No, just a thin reflective foil. Looks like it's two layers of Polyethylene with vapor deposited aluminum between. It doesn't insulate by itself, just reflects IR back from the underside of the roof.
01-04-14, 03:49 PM | #4 |
01-10-14, 08:06 PM | #5 |
I have a couple questions for you. What style of roof do you have, Gambrel, hip roof, Mansard? A picture would be great. How is your attic vented? Were you concerned about wind knocking the barrier down?
01-10-14, 11:11 PM | #6 |
Could this product work in cold Climates to redirect heat back into the house ?
I wonder if it would conserve energy/heat if you were to use it foil side facing in on a inside ceiling to reflect radiant heat back into the house on a cold winters day.. or would using it foil side up on the inside ceiling be better in such a application ? Last edited by ecomodded; 01-10-14 at 11:19 PM.. |
01-11-14, 02:37 PM | #7 | |
01-11-14, 04:07 PM | #8 |
In a fully insulated house. If it was installed under the drywall foil side facing in to act as a radiant barrier to keep heat in it, for new construction or a extensive reno.
Seems to me they have foil faced fiberglass insulation not sure what side they face up.. |
01-12-14, 03:41 PM | #9 |
I found this on a Gov. website
Most common insulation materials work by slowing conductive heat flow and -- to a lesser extent -- convective heat flow. Radiant barriers and reflective insulation systems work by reducing radiant heat gain. To be effective, the reflective surface must face an air space. Dust accumulation on the reflective surface will reduce its reflective capability. The radiant barrier should be installed in a manner to minimize dust accumulation on the reflective surface. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ it would need to be glued to the ceiling reflective side facing in. Radiation losses Radiation losses can be reduced by using special plasterboard that is backed with a sheet of aluminum foil. The shiny metal foil acts as reflector of infrared radiation. Some of the infrared radiation is reflected back into the room and heat losses by radiation are therefore reduced. Metal foil placed behind a radiator that is fixed to an outside wall also helps to reduce heat losses by radiation. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ So you can stop radiation losses. |
01-12-14, 04:12 PM | #10 |
Well, the foil faces the living space. I have the the roof decking that has the foil on the underside of it. Called Techshield.LP Building Products | LP TechShield Radiant Barrier
I can vouch for using just plain old Standard weight Aluminum foil as a way to keep the heat in the house. [IMG][/IMG] Read more here starting at post #14................. http://ecorenovator.org/forum/applia....html#post9662 If I were going to retrofit foil in my attic I would use this something way less expensive than the product at Lowes or Home Depot........... FOIL ROLL 18"X1000' ROLL STANDARD WEIGHT FOIL - Dean Supply |
