09-01-14, 11:46 AM | #1 |
Poly-Iso Insulating Foam R-value is Changing...
Various foam R-values get discussed a lot on this forum, so I thought it would be of interest to know that new testing procedures are being applied.
R-value is being reduced from R-6/inch to R-5.7/inch SEE_ANNOUNCEMENT There could be other changes to other materials, too. -AC
The Following 2 Users Say Thank You to AC_Hacker For This Useful Post: |
09-01-14, 06:37 PM | #2 |
The same holds true for 2lb urethane foam and isonine foam. Long term tests show a settling of R values for most foams.
The Following User Says Thank You to Mikesolar For This Useful Post: | buffalobillpatrick (09-11-14) |
