#1 |
Home-Wrecker
![]() I was doing some demolition work recently, which happened to include removal of just over 50 2'X2' plastic mirror tiles from a suspended ceiling.
I was able to take the mirror tiles, and am trying to decide what's going to be the best use for them. I was thinking that they might best be used for some sort of solar project. They could be used in a number of ways: A: Set up outside to reflect more like into house in the winter B: Use as reflectors to increase efficiency of solar panels (solar water or PV) C: Build solar ovens D: Build some sort of solar concentrator E: Other Use? Anyone have any other ideas for how to use this material? Some good use for it besides solar? Let me know
#2 |
![]() Use them to reflect away sunlight during the summer.
#3 |
![]() Make a dance studio?
#4 |
#5 |
![]() I wonder if the tiles should be used outside in the direct sun? I'm thinking about quick deterioration from heat and UV.
But if you make a dance studio, then I just might come by a few times ![]() |
Tags |
mirror, plastic, solar |
