07-23-15, 04:10 AM | #1 |
Can I use ni-mh batteries in my garden solar lights?
The solar light batteries in my garden are dead. Upon replacing them, I realized they were the old Ni-Cd rechargeable batteries.
I have heard that these batteries are not so good for the environment because they contain toxic chemicals (see Wikipedia). I would like to use Ni-MH batteries instead. Would this be recommended or will slowly charging these batteries using solar panels shorten its life span? |
07-23-15, 08:03 PM | #2 |
They will work great. Nimh batteries typically have 50 per cent more capacity vs nicd in the same size and do not build up memory as bad as nicd batteries.
07-24-15, 07:43 PM | #3 |
They both accept the overcharging abuse of long sunny days with no charge control equally well. If you were charging them at a high rate with a NiCd charger, they have the potential to overcharge at a high rate, generate a bunch of heat and usually fail quickly. With a slow charge from a solar panel, it's a non-issue.
