02-11-16, 02:20 AM | #1 |
how to lose weight fast
Split install
How to I install Split install
Sorry, new users are not permitted to post links in their signatures. |
02-16-16, 08:29 PM | #3 |
The first thing you want to do is make a guess about the brand name and the model of Mini-split you might want to install, then download and study the installation manual. Then take a look at the threads on this page about installing mini-splits. There used to be some pretty good install videos on youtube for a few brands..
My hobby is installing & trying to repair mini-splits EPA 608 Type 1 Technician Certification ~ 5 lbs or less.. Last edited by Xringer; 02-16-16 at 08:30 PM.. Reason: edit |
02-21-16, 10:57 AM | #4 |
Ask yourself , how much HVAC or construction or DIY experience you have . Same question on tooling .
Ask yourself how much studying you are willing to do . How much work you are willing to do . Will you have any help . What is their knowledge base . How much are you willing to spend on tooling ? Most anyone can buy a window unit , set it in the window , adjust the side pieces , close the window & plug the cord in ( especially if the unit is 120 VAC ) . Any kind of split system involves dealing with refrigeration lines and refrigerant . And all that entails . Are you up to that ? So , if you are going ahead with it , sit down and start making a list . What room do you wish to install the mini split in ? How many square feet is the room ? Does it face N , S , E or W ? Sots of windows or few ? How well is it insulated . Now , you can start to decide the capacity ( BTU's ) you will need . If you need help , ask and I am sure someone here can help . Now , decide on your budget . Figure out what your tooling cost will add up to . Subtract that from your budget . The difference is the amount you have to spend on HVAC equipment . I recommend you buy the highest efficiency equipment , that you can , with in those dollar amount . We have installed 2 MS's in out house . If it was not for cost , I would install more . God bless Wyr |
Tags |
mini split, mini splits hp, mini-split, minisplit, splitter |
