03-04-13, 08:04 AM | #1 |
hvac & heating
I'm totally new to HVAC. I've installed 2 minisplits (permitted, inspected and passed by the local inspectors) and maintained 7 personally owned units for about 7 years now. I took the local A/C courses after being screwed by two contractors in succession. This is the first time I've ran into a heating problem with a pure HVAC system. Found a blown fuse and now its up and running fine.. BUT ... How do I know that it is working efficiently. I can't even find a guideline for ball park opertating conditions. Yesterday here in VA. it was about 50 degrees outside. I had 150psi on the high side and 50 psi on the low side at the compressor. The temp on those lines were 126 deg / 58 deg F. inside differential was about 24 degrees. Are there some old fashioned ball park guidelines in this regard??? thanks
03-04-13, 10:15 AM | #2 | |
Also, what exactly causes your concern with the performance at this time? Are tenants complaining? Has you power bill increased inexplicably? -AC
03-04-13, 07:14 PM | #3 |
sop for Hvac heating
I have a number of rental units and carry a nice Ir temp probe with me at all times. If I am in the house to change the filters which I do, I always check the temps and note them. This is a 10 year old R22 (`13Seer) system. 2 years ago I had a new airhandler installed with a txv (?) that was about 2 time the size of the original and the electric bill dropped substantially I have been to several schools, have my license but it is for my own use only. I do no commercial or outside work but have found that the classes though informative have little use or are not a substitute for on the job experience.. Actually dont the tempratures I liste give you a good idea of what the refigerant was? R410 pressures would have been much higher and I dont know of any legal substitutes that might be used, though I have tested systems using propane and had them working just fine...
