Old 06-20-21, 07:03 AM   #1
nokiasixteth
Default Duramax generator to big propane tank
I have the duramax 5500 generator dual fuel and only have ran it on propane small bottles . I use it when grid goes down and there is no sun for the solar panels to be on.
I have a big 150 gallon or so propane tank i want to use instead of the small gas grill tanks. Question is has any one done that before on here that can shoot pointers to me.
nokiasixteth is offline   Reply With Quote
Old 06-21-21, 09:46 AM   #2
It sounds like you'll just need to convert from whatever valve fitting the 150 gallon tank has to whatever the 20lb tanks have to get to the inlet on the generator. Gas is gas. The supply doesn't matter too much as long as its regulated the same.
nokiasixteth (06-21-21)
Old 06-21-21, 08:19 PM   #3
nokiasixteth
Thanks . I wasnt sure if it was a higher pressure regulator or something.
