Old 09-20-11, 04:14 PM   #1
Default Dual Digital F/C PID Temperature Controller ??
Anyone here ever work with these PID gizmos?
They don't cost too much..
eBay -
And, they sound very interesting..
PID controller - Wikipedia, the free encyclopedia
I've seen were people are using these for fancy coffee makers, to keep their temperature at +/- 1deg..
I think they were using a digital pulse output to an SSR..
I've been looking at PIDs, wondering if they could be used to control the water temp,
in my boiler, by switching a ASHP off and on, (No digital pulses).
My first impression is, these PIDs are smart and learn when to shut down
early, before over-shoot comes into play.. Anyone up on these things?
Thanks,
Rich
Old 09-22-11, 02:14 PM   #2
I found some "Settings" info at this link,
DIN Digital PID Temperature Control Controller 100-240V 12VDC&Relay with Sensor | eBay
That gives me an idea of what these things do..
Here's a Plain Jane temp controller..
eBay Temp control
Old 09-24-11, 01:19 PM   #3
silverinsight2
I calibrate these things all the time at work, I've never had to replace one.
silverinsight2 is offline   Reply With Quote
Old 02-02-12, 08:38 AM   #4
abogart
Efficiency Afficionado
abogart's Avatar
I have been looking at these lately too. They are SOOOOO cheap (like $25) and have so many functions and applications. I just can't seem to find at way to integrate one of them into any of my systems. They seem to work great for on-off pulsing applications, like electric resistance heaters. At the foundry they used them to control core box temperature on the core machines. In this system the PID controlled a servo gas/air valve that had two positions: high-fire and low-fire, controlling the flame of natural gas burners. The servo valves would have been perfectly capable of any setting in between, but the PID only pulsed between the high and low settings. They did, however, seem to do a nice job of maintaining temperature.
I would like to figure out how to get a PID to control damper position. This could be a good retrofit for my woodstove, having the PID control a combustion air damper to maintain a set flue stack temperature. However, open-closed - or even high-fire, low-fire for that matter - doesn't fare too well with woodstoves. They like a consistent air supply. I have thought about finding a way to tune one to pulse a damper motor open or closed at a wide interval. I'm not sure if that would work very well, but it might be worth a shot.
These little gizmos are just too appealing not to use for SOMETHING.
abogart is offline   Reply With Quote
Old 02-02-12, 09:00 AM   #5
If there isn't a way to program the PID so it doesn't pulse, a 555 timer could be used to stretch the pulses out..
I did that with my current (amps) controller..
http://ecorenovator.org/forum/applia...limiter-4.html
I wonder if a damper controller could be made using a model airplane RC servo?
If you can vary a pulse width, you can set a damper to a LOT of different positions..
R/C Servo Timing Waveforms - YouTube
abogart (02-02-12)
Old 02-02-12, 11:31 AM   #6
abogart
abogart's Avatar
I think the real challenge lies in converting the PID's "duty cycle" into a damper position. In other words, 10% duty cycle from the PID results in 10% damper opening, and so forth. I think the easy way to do this would be to use two PIDs, One for determining how much the damper needs to be open, and the other for reading the position of the damper and determining how long and which direction the motor needs to run. I'm not sure how one would go about transmitting the duty cycle from the first PID to be ready as an input on the second PID. Unless there's another type of controller for something like that.
I think we need someone that has experience with these industrial process controls to chime in here...
Either way, it seems like the high-fire/low-fire idea might be worth playing around with. Adjusting the limits (or whatever they use) on the damper between two intermediate positions - say 25% to 75%. There is still a chance that the PID could auto-tune itself or be tuned to adjust variably. It would still probably be more efficient than leaving the damper at a single setting throughout the entire burn.
Old 03-29-12, 08:56 AM   #7
I've decided to go with a simpler device..
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
Posted about this one before..
http://ecorenovator.org/forum/sale-t...ontroller.html
It has firmware that can be used to control heat pumps. (or fish tanks)
