Old 12-22-13, 10:17 PM   #1
opiesche
Default DIY 3D printed recessed LED fixtures
[EDIT] sorry, some of the pictures are upside down.
So, the original 1980s light fixtures in our upstairs hallway have always bothered me a bit. They just look... well, so 1980s. Since I've built fixtures out of LED modules and strips for both my office and kitchen, I figured why not replace those too. For the hallway though, after talking it over with the wife, we wanted recessed lights.
I did a little shopping and found several different options - all of them outrageously expensive, $30 and up. Since we wanted two rows of 5 each along the hall, that could have gotten expensive real quick.
Back in September, I got a 3D printer for my birthday. So, earlier today I set out to design my own simple recessed LED fixture, and about an hour ago I installed the first two!
The fixture itself consists of two parts, top and bottom. The bottom is sized so that it exactly fits into the hole my 65mm hole saw makes into the drywall, tight enough to not need any adhesive.
The top is designed to thread the wires of one of my go-to LED modules (4 5050 type SMD LEDs in one small module), through and glue the module itself to the center strip:
There's a 1mm lip around the inside of the bottom half, designed to catch a piece of acrylic cut to size with the same hole saw. It fits in perfectly and lays on top of the lip, again without needing any adhesive.
Then the top just slots into the bottom piece.
So, I just cut a hole in the drywall from below, push the bottom part in. Then wire the modules from above, and just drop them into the fixtures from the attic. It takes about 10 minutes to wire and install two of these. They're extremely low profile (only about 16mm tall), and since the LED modules run on about 0.8W each, heat is negligible.
Here's a shot of the bottom half of one being printed:
ID:	3798   Click image for larger version
ID:	3799   Click image for larger version
ID:	3803   Click image for larger version
ID:	3804   Click image for larger version
ID:	3806   Click image for larger version
ID:	3807   Click image for larger version
opiesche is offline   Reply With Quote
The Following 4 Users Say Thank You to opiesche For This Useful Post:
Daox (12-23-13), jeff88 (12-23-13), Mikesolar (02-09-14), Ryland (12-23-13)
Old 12-23-13, 01:23 AM   #2
Originally Posted by opiesche View Post
[EDIT] sorry, some of the pictures are upside down...
You're photos are very nice, but there is nothing in the photos that warrants an image size of 3049 x 2287 pixels. 800 x 600 pixels would be more than enough resolution.
Resizing is easily done with whatever basic graphic editor your computer came with.
It will make uploading less of a chore for you, and less of a chore for all the people who might click on your post.
It took me about 5 minutes for your images to come in... long enough for me to write this message to you.
Bandwidth isn't free.
Old 12-23-13, 01:25 AM   #3
opiesche
Apologies. I took the shots on my cell phone and just uploaded them without checking size first. I'll edit the post with resized images.
Old 12-23-13, 01:31 AM   #4
opiesche
All fixed!
Old 12-23-13, 03:16 AM   #5
jeff88
Lots of questions
That is really cool! I wish I had a printer. Oh, the things I could build!
There's just one thing. You say the $30 per fixture X the number of fixtures could end up being too much, but you have a 3D printer?!?!
jeff88 is offline   Reply With Quote
Old 12-23-13, 03:29 AM   #6
opiesche
Hah, good point!
I got the printer anyway, simply because I wanted one (and oh how useful it's been already!). The kit was $399, and with these lights and some of the other things I've printed, it's more or less paid for itself already.
I'm not necessarily saying that the 300-400 bucks for the lights would have been completely unaffordable - but for what you get, which is essentially a can with a light in it, it's ridiculously overpriced. I'm a fan of balance - essentially, the price/value ratio of the factory made fixtures just blew my mind, especially since it's I managed to make ones that work fine and look nice at a cost of about $1.50 a piece - and that's including the light!
Of course there's the issue of the rating. I can't very well get my printed housings rated for direct insulation contact, although I know full well that they'll never get hot enough to be a problem. In the end, that might mean that if I ever sell this place, I'll have to place some 6" pipe or so around each of the fixtures in the attic and sacrifice some attic insulation performance for the future owner :P
Old 12-23-13, 07:45 AM   #7
Pretty cool stuff! Thanks for sharing. Lucky guy with a 3d printer...
Old 12-23-13, 08:22 AM   #8
hamsterpower
Are the wire connections contained? It looks like the wires leave through the top and are exposed to the attic. All wire connections need to be in a box.
hamsterpower is offline   Reply With Quote
Old 12-23-13, 10:23 AM   #9
[EDIT]...Back in September, I got a 3D printer for my birthday. So, earlier today I set out to design my own simple recessed LED fixture, and about an hour ago I installed the first two!...
This is really great!
I bought a little CNC router kit (ZEN) just to see what this CNC thing was all about. I learned a lot from the experience. Enough that I am collecting parts to make my small milling machine CNC, too.
So, back to the ZEN, I have all the hardware working under computer control, and I think it should be possible to adopt it to 3D printing.
I'm impressed that you've been able to fashion something as utilitarian as a light housing!
So far, I've just seen people make hollow spheres and pretty plastic spirals and tiny tea pots with removable lids.
I'm not being ironic when I say that making utilitarian items is a big step forward.
Awesome.
Old 12-23-13, 12:04 PM   #10
jeff88
Lots of questions
That is waaaaaay cheaper than I thought you were going to say! I've only seen them in the thousands. Basically your printer just paid for itself with this project.
