Old 07-18-16, 04:52 PM   #1
Default Santa Fe Classic Dehumidifier
This looks like the perfect unit for my basement!
Buy Santa Fe Classic Basement & Whole House Dehumidifier (4029700) | Thermastor 4029700
Capacity @ AHAM: 110 Pints/Day
Capacity @ Saturation: 180 Pints/Day
Amp Draw: 6.4 Amps
CFM: 275 CFM
Operating Temp. Range: 56° - 95°F
Wow! Listed at $1,671.00 Got it off craigslist for $100
See: http://ecorenovator.org/forum/sale-t...list-used.html
It seems to be working Okay. In ideal conditions, it pumped a cup of water in about 35 minutes.
After I install some filters, I'll give it a good test run.. It does use about 6.4 Amps at 120vac..
Old 07-18-16, 05:39 PM   #2
pinballlooking
pinballlooking's Avatar
Great deal.
Solar Install 12.5 Kwh-
Mini Split installs -
EV Chevy Volt -
Old 07-19-16, 10:28 PM   #3
Gut shots? Or did it already get installed somewhere?
Old 07-19-16, 11:55 PM   #4
I think it's a 6 or 7 years old. Recently replaced. No explanation of why..
But, when I did a short test the day of delivery, it was idea weather for a test. Raining & 80F. in an open garage.
Looking at the amount of water that came out. I estimate 1/2 quart per hour. (or less).
Spec says under idea conditions, 2 quarts per hour.
On some of the reviews I've seen, there were owners saying that refrigerant slowly leaked out. (4 or 5 years)
I hope that's all that's wrong with this one.Hope it just needs a shot of R410A..
Planning to test some more when I get some air filters.
Noticed the compressor got really hot. Wondering what the normal operating temperature is.?.
Old 07-21-16, 02:05 PM   #5
The maintenance port is out on a thin tube..
I can see how it might get broke off when removing the cap..
Old 07-23-16, 05:05 PM   #6
Default Pressure test?
If I put a gauge on the low pressure port while the unit is running, I should see about 240 PSI?
Or, is that the Max pressure? On a mini-split, it seems like 130-140 PSI is common..
Old 07-25-16, 01:12 PM   #7
Default Kinda working..
I'm not so sure.. I found a user that's had a lot of problems with this model..
Sante Fe Classic Quality Issues
He's included five links to YouTube videos in his posts..
Mine seems to be working poorly. Only getting about a quart during a 1 hour run..
Temp 70F with RH between 60 & 70 percent.
I'm wondering if a Superheat test could tell me anything..
First, I'll have to find out what the 'standard' Superheat temperature is for this model. At 70F & 70%RH..
After a 1/2 hour warm up, I did a little testing of the input air vs the output air.
Input air was 62%RH @ 73deg
Output was 38%RH @ 82deg
A change of 24%RH & 9 deg.
Old 07-30-16, 01:56 PM   #8
JRMichler
Maybe I'm lucky or something, but we bought a Thermastor Santa Fe Classic dehumidifier in 2003. We put it in the living room to use as a whole house dehumidifier in summer. It's been working perfectly ever since.
The house temperature is typically 75 to 80 deg F, humidity 45 to 50%. The house is well insulated, so we rarely use the AC. Also, the AC does not do a good job of removing moisture.
My wife likes it dry, sometimes the humidity gets down to 40%.
Old 07-30-16, 02:10 PM   #9
Wow! That sounds like money well spent.
Is it a R22 or R401a version? I'm also very interested in the temperature of the input air, vs the output air.
I think it might be a quick way to determine the correct refrigerant load.
If I can get this one working to spec, it would be fantastic for our musky basement..
Old 07-31-16, 08:15 PM   #10
JRMichler
The nameplate says R22. It's running right now. The room temperature is 76 deg F, 53% RH, outlet temperature is 100 deg F. The outlet temperature reading may be a little low, it's a cheap little thermometer laying on the floor.
