#1 |
![]() Hi all,
I am solar-projects fan. Proud to say that I am already using pop can solar air heater already mounted on my house... I have started couple more wind small-turbine project, and this forum seems like a great source for new ideas. I would like to share some.. regards,
#2 |
![]() Welcome to the site.
Do you have any pictures and/or info you care to share about your solar pop can collector?
#3 |
![]() Yes :-)
but as a new user I am not allowed to add pictures in posts (at least this was message when I tried to attach picture) :-(
#4 |
![]() This is collector mounted...
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by Mladen; 11-11-11 at 01:05 PM.. Reason: typing err |
#5 |
![]() Looks good. If you made it the entire length of the balcony I don't know if anyone would even notice it.
Any idea how much it's helping with the heating bill? |
#6 |
![]() It is little hard to compare bills, but I know that my original central heating (electrical) is OFF during 4-6 sunny hours per day, even outdoor temp is just few degrees above zero Celsius (38F),or below, because collector blows hot air :-)
since it cost me around $200, it will pay itself in just one year or so... You are right about longer collector would be better and more pretty, but I had to make it in one piece and polycarbonate sheet was with fixed dimensions... regards,
#7 |
![]() nice project mladen. I look forward to seeing more. cheers
