Go Back   EcoRenovator > Improvements > EcoRenovator Blog Discussion
Old 10-19-09, 06:19 AM   #1
SVOboy
SVOboy's Avatar
Default DIY Ground Source Heat Pump: Part 8 – Building The Loop Field
This entry is part 8 of 8 in the series DIY Ground Source Heat Pump The holes have been bored, and the trenches have been dug. Now, it is time to put the tubing into the ground to build the loop field. This means connecting up all the loops that have been put down [...]Post from: EcoRenovator.org
More...
