Go Back   EcoRenovator > Off Topic > For Sale / Trade / Wanted / Web Finds
Old 12-18-16, 08:00 PM   #1
Default Refrigerant Charging Scale US $78.09
My 30 pound max baby scale has a problem working at the high end of it's range.. Not gonna work..
Saw this unit on Ebay.. And same model at Amazon for a bit more..
One good review too.. https://www.amazon.com/Zeny-Electron.../dp/B014RHV87A
220 lbs Electronic Refrigerant Charging Digital Weight Scale with Case for HVAC | eBay
Anyways, the question to the old Pros..
Will this scale be good enough for a DIYer who uses it a few time per year?
PS: This scale would be used with the stuff on http://ecorenovator.org/forum/sale-t...y-machine.html
Thanks for any comments..
Old 12-24-16, 02:01 PM   #2
Never mind.. I'll find out when it gets here..
Hope it's better than trying to use a bathroom scale.. (Terrible for items in the 20-30 pound range)!
Old 12-26-16, 04:53 PM   #3
CrankyDoug
I've been looking at those for about two years - kept putting it off because I was concerned about accuracy/repeatability.
Let us know what you find.
Doug
Old 12-26-16, 06:06 PM   #4
There is one nice review on Amazon..
https://www.amazon.com/review/R3CVSVK7VW7VSN
I will post a review on Amazon, and here..
I have my empty recovery tank that I can use to see how good the basic accuracy is..
Then I should be able use some 1 to 5 pound weights to see if it can measure
small amounts of weight added to and taken away from the main tank weight..
The only thing that's worrying me, is the time-out. Will it turn off in the middle of operations.?.
That should be very easy to test..
Old 01-03-17, 10:32 PM   #5
skqueproducts
Been looking for these as well.
skqueproducts is offline   Reply With Quote
Old 01-03-17, 11:01 PM   #6
A small review is posted here: http://ecorenovator.org/forum/tools/...le-review.html
And at Amazon..
Old 01-04-17, 09:13 AM   #7
pinballlooking
pinballlooking's Avatar
I used my shipping scale last time I recharged my mini split. It is just two decimal points but it is pretty accurate.
The scale you bought is nicer so if it was doing this type work more I think I would get one like this one.
Solar Install 12.5 Kwh-
Mini Split installs -
EV Chevy Volt -
Old 01-04-17, 09:48 AM   #8
I'm gonna be a Grand Dad very soon, so I'll be able to check the accuracy
of the scale that I got for my grandson, https://www.amazon.com/gp/product/B0009MFUZE
I'll use one of the 10 pound weights as my standard.. In the ounces mode..
Yeah, I think he's gonna be big!
Old 01-11-17, 10:36 AM   #9
Elcam84
I would trust it allot more than I would a bathroom scale. Those are not very accurate across the scale and not that great are lower weights.
I haven't used that item but I have found the accuracy of similar items are the quite good.
Old 01-11-17, 11:47 AM   #10
WyrTwister
I have used an electronic bathroom scale . Not the best in the world . :-(
And it timed out too quickly . I had to repeatably pick up the refrigerant jug and sit it back down on the scale to get the scale to " wake up " again . :-(
Be interested on your comments after you have a chance to use it .
God bless
Wyr
