Old 08-12-18, 01:05 PM   #1
bulldozer
Default root cellar w/ earth tubes
Building an addition to home and wanting to put a root cellar in the basement. To help with ventilation and keep it cooler in the summer I'm thinking about a earth tube system. My proposed system is as follows; root cellar will be 9x6', ventilation would be one 4" pvc pipe ran underneath the garage slab (elevations are offset in profile) for ~40' to open air in a shaded corner on the exterior. There would be a sealed pipe extending upward thru roof w/ a turbine vent. Inlet pipe would be within 1' of the cellar floor and exit would be within 6" of ceiling. My hopes is that the roof turbine would create enough suction to draw outside air thru piping under garage slab, cooling air, and cool/ventilate cellar. I imagine this working as a passive system. As described can you see any hiccups in design that need worked out prior to build? My main concern is airflow, I'm worried that the outlet would have a much higher cfm then inlet. Would one 4" inlet support a 4" outlet with assisted flow?
bulldozer is offline   Reply With Quote
Old 08-12-18, 01:31 PM   #2
bulldozer
While looking up cfm for turbine vents, now I'm thinking I need more volume in system. What are thoughts on inlet piping, having 4" entering into cellar and at exit however having 12" piping for run to increase volume. I'm thinking possibly two 12" "storage" sections of piping with 4" inlet and outlet. pipe run from outside to cellar, 4" pipe for first 4' then splits to two 12" pipes then back to a single 4" pipe into cellar. Not sure if the splitting and pipe reductions would greatly affect the air flow, same size on either side.
Old 08-13-18, 12:48 PM   #3
natethebrown
Here is a really great video I saw that might help you figure out the best path forward:
The Following User Says Thank You to natethebrown For This Useful Post:
jeff5may (08-13-18)
Old 08-13-18, 10:18 PM   #4
Slow airflow that is ground Temperature makes a good growth chamber for mold, especially if it is humid. Unless you want to grow mushrooms, having a little breeze is not bad. If you need more surface area, it's better to run multiple smaller diameter pipes. I like the green PVC storm drain pipes. They have thin walls, too.
