#1 |
X-Frenchy: very
![]() I haven't found cheap/free 2nd hand solar panels yet, but thanks to Gascort I'm thinking about building my own... then I'm imagining where to put put these cells and so how to design the shape of the panels...
One question I have : when is a charge controller needed ? My current cases are :
I think that in both cases, the panels are too weak to damage the 50Ah 12V batteries. From which wattage does a charge controller is needed ? Denis.
Earth absorbs 1.8 t CO2/head/yr, while a French generates 6.2 t CO2/yr To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
#2 |
![]() I think anything over 2A is probably good to have a charge controller for. But, that is a total guess. I say 2A just because thats what most trickle chargers put out. I'm not sure they lower their amperage after they hit full charge.
