Old 07-26-12, 10:03 AM   #1
Default UV from CFLs?
Scientific study proves energy efficient bulbs can harm human skin cells - National Science & Space | Examiner.com
Heard about this on the news. Wonder if it's true.?.
If it proves to be even partly true, this is going to increase LED sales..
Almost all my remaining CFLs are installed inside light fixtures with frosted glass or plastic, filtering the light. (Which might be blocking out some of the UV).?.
The CFLs that are not in fixtures are either outdoors or, in rarely used basement areas.
Old 07-26-12, 12:31 PM   #2
Meh, publicity stunt IMO. I've worked under FLs (not compact, but virtually the same) my entire life. I think I'd notice sunburn from them if it happened. Can't tell you the last time I was less than 8 inches from a light for hours on end. Seems pretty sensationalized to me.
The European report had found that some CFLs emit UV radiation, which under prolonged exposures at short distances (less than 8 inches) may approach the workplace limit set to protect workers from skin and retinal damage.
Old 07-26-12, 01:35 PM   #3
I've had my hands right under a small FL for hundreds of hours, and never got sunburned hands.
But, if there is any evidence at all, that skin or eye damage can occur at 8",
then the question is going to be, at what distance would CFLs be 100% safe.?. 8 feet??
My guess is, if you are close enough, and the CFL is strong enough to give you UV burns,
you will be able to feel considerable heat from the lamp!
So, you won't be very comfortable while getting the burn.
Old 07-27-12, 04:59 PM   #4
menaus2
Location: Driftless Region, North America, Earth, Solar System, Orion Arm, Milky Way Galaxy,Virgo Supercluster
I can pretty much guarantee you get more UV exposure from the sun. There are florescent tubes made specifically for UV (blacklights) and there are no warnings associated with them. I wouldn't worry about this.
menaus2 is offline   Reply With Quote
