03-23-10, 03:37 AM | #1 | |
Increasing transformer efficiency
All electronics are really DC powered, even though they are fed AC from the grid, which means that each TV, DVD, SAT, stereo, computer, etc., has a transformer+rectifier inside. How efficient is that? Would it be more efficient to have one larger transformer supplying power to the LCD/DVD/SAT/home theater bundle in the living room (hacking those devices to directly input DC)?
From Wikipedia - Tranformer, Energy losses: Quote:
So the question remains: Several small transformers, or one larger one? |
03-23-10, 06:15 AM | #2 |
Well, since everything is designed to use AC, you'd have to hack every single item to run off DC. Even then, you don't know what voltage its running inside it, or it might be running multiple voltages...
I think that with modern devices and the emphasis on power saving features that has come about in more recent years, things are definitely getting a lot better.
03-23-10, 08:21 AM | #3 |
In general, one large power supply is more efficient than several smaller ones. In addition, in a network environment, you then get additional losses converting AC to DC then back to AC in the UPS.
One of my current projects is the "Allie Moore IPS-35A15V", a high efficiency power supply for my home network. It will supply 12-15V (programmable by a BMS or PMS) at up to 35A to float charge a 12V battery and operate loads. Most home networking equipment use 12V so they can simply be connected to the 12V bus. Other devices use DC/DC converters. (I also plan to develop the "Allie Moore ATX-400DC12V", a 12V DC input ATX power supply.)
03-23-10, 03:12 PM | #4 | |
Wannabe greenie
Combining power supplies makes sense in a single area where multiple devices reside (as in NiHaoMike's example), but higher voltage moves with less loss over the same wires, so it's more lossy to run, say, 12V all over the house than it is to have individual power supplies tapping off 120V or 240V. |
The Following User Says Thank You to Clev For This Useful Post: | Servicetech (11-09-13) |
11-09-13, 02:07 PM | #5 | |
