To answer the question, yes this model is a bit better than other models for a typical homeowner.
Most heat pump water heaters are hybrids in order to meet the wide array of demands. They tend to fall back on using electric heating elements quickly. A prior reply noted a situation in which a homeowner did this and why. The heating elements are old school style so they must be mounted lower in tank
If you know you have a location where the heat pump can work year round, and you won't typically empty the tank, but use a fair amount of hot water (family) then this model is optimized to take most advantage of heat pump savings.
Keep in mind it is a MASSIVE 80 gallon model with a heat pump on top, 6 Feet tall and close to 1 Ton in weight filled with water.
This model is effectively an ASHP with an on demand electric element at it's outlet.
