Old 02-09-13, 09:58 PM   #3
randen
Uber EcoRenovator
Default 5 Ton GSHP Build
Most of the components have arrived and are being assembled. A few alterations have been nessisary. The height of the new compressor is about an inch taller and its having a bit of a snowball effect with now the case not being tall enough and the reversing valve position. In true Ecorenovator fashion the new build is also sporting a suction tube heat exchanger. Mikesolar and Jeff have done some work showing some efficiency gain but we'll have to see what happens
The varible frequency drive VFD is taking its time arriving. But until the final strokes are completed on the 5 Ton the little 2 Ton will keep the shop almost warm.
Up grades to the 5 Ton:
scroll type compressor
VFD
Liquid sight glass
new filter/dryer
Suction line HX.
Randen
The Following 3 Users Say Thank You to randen For This Useful Post:
b420ady (11-18-16), buffalobillpatrick (05-24-14), ctgottapee (02-13-16)
