I think solar is very sexy! Charging EV’s on solar is even more sexy.
I laughed out loud thinking I am probably one of the few people that thanks that way.
It was fun watching your solar journey.
We used some similar products. My project was 100% DIY but my roof pitch was not as steep as yours.
My system has 54 panels so a few more trips up the roof 😊
My power company will not allow a breaker disconnect switch like yours. They require a blade type switch that has a physical switch movement.
Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
