I've kind of been looking for a new router and I remembered this thread. I started poking around looking for something that would work for me and I ended up finding this product. I haven't read any reviews (except the one on newegg), but the power saving features sound really nice. As of right now newegg is selling it for $61 which seems pretty reasonable. Unfortunately it doesn't actually tell you how much power the unit draws in power saving mode or max.
LevelOne Global - WBR-6020 300Mbps Wireless Router
Wireless On/Off Button
The wireless radio is one of the most power intensive components. With a simple push of a button, you can disable the wireless radio when it’s not needed.
Low Power Wireless Mode
When there are no wireless devices connected to the WBR-6020, it will automatically only keep one antenna active in low power mode.
Active Link Detection
The WBR-6020 can tell if there is any activity on each individual LAN port. If there are only 2 active devices connected to the WBR-6020 LAN ports, then the remaining 2 LAN ports will be powered down.
Scheduled Sleep
Typically, your wireless router will only be used while you are working. You can set the times that the router will automatically sleep and wake, so that it can also rest while you are sleeping.
On top of the Power-saving features, the WBR-6020 will also use over 80% recycled packaging materials and have an Energy Efficient power adapter.
