Old 05-11-10, 11:22 PM   #13
Originally Posted by kbhale View Post
Note the concave bottom. Going to clean it up and make it water tight. Then put it where the bowl is now. Might insulate it and cover it with another barrel.
I guess you have installed an alternate exhaust chimney to allow smoke to move up the smoke stack.
Does that bowl get really hot?
It seems like putting that tank on top (where the bowl is now) will be like
a dead-end heat-pocket that's not going to be as hot as the heated air
and exhaust gases flowing up & out of the main Rocket stove chimney.
