Old 07-25-19, 08:18 PM   #729
pinballlooking
pinballlooking's Avatar
It looks like the new solar disconnect switch guts fixed the one leg going low issue.
We have a nice clean solar production day. Good to have it back running the way it should again.
The switch started to have issues when I was staying at the lake so this month’s solar will take a small hit.
This month is usually a great month so it is to bad it will be lower. We have 1,360 Kwh banked so far for the winter.
I like to go into the winter with 3,000 Kwh banked but we will see if I can bank that much.
I bought a spare disconnect switch just like the other one. I got it for $37 shipped. I will just put it on the shelf hopefully I will not need it. if I do need it i will have it on hand to swap out the internals. It does not take to many sunny days to loose money if system is not working.
Solar Install 12.5 Kwh-
Mini Split installs -
EV Chevy Volt -
