Old 07-24-19, 08:11 PM   #728
pinballlooking
pinballlooking's Avatar
Originally Posted by pinballlooking View Post
I had been having trouble with my disconnect switch. At peek times it would make one leg have low voltage.
I exercise the switch it would work good for a while. As you look at this picture it was the top right below the red that was the issue.
Below that is a knife switch that has pressure to make a good connection.
I ordered a new disconnect switch off eBay knowing I had a new coming I took off the red cover and bent the pressure switch. (This was on Aug 26)
This allows it to have more pressure on the knife switch. It has worked flawless since then. I still might swap it out over the winter but not one hiccup with it so far.
I did learn that this switch has an override to allow you open the box without exercising the switch. If I would have known that from the beginning I would have found the issue much sooner.
This type of switch is required by my power company.
Will it worked almost a year (after bending the tab for more pressure) the but it started having one leg low again.
I had bought the exact same switch. This worked out great.
I was able to leave the steel box and the switch and just replace all the components inside the box.
Solar Install 12.5 Kwh-
Mini Split installs -
EV Chevy Volt -
