Old 10-04-09, 10:02 AM   #8
After seeing the very poor job our HVAC guys at work did on the 24KLS72
line-set install, I'm thinking of buying my own Sears flare tool and DIY.
Sears.com
I see the manual refers to a 'special R410A flare tool' and "RIGID",
but there just isn't enough info about which tool I need.
Sears has a bunch of them, but I need some tips on what to look for..
Thanks,
Rich
Rich,
As a disclaimer:
(* I am not a refrigeration technician. If you do the work yourself, you're voiding your warantee. *)
But I did mine myself and it's working just great.
I didn't change my lineset, so you will need to verify that the R-410a flare fitting is not substantially different from other flare fittings. I do think it has a different diameter but you should still be able to use common flare tools.
Will you be doing the entire install yourself?
I installed mine, and I can tell you what I did, if you are interested...
Regards,
