This is just a poly capacitor.
The way you read the identification is:
335 = 3300000 picofarads (0.000003300000 pico = 10 minus 12- there are five zeros before the 33) or 3.3 microfarads (micro = 10 to the minus 6, you search it by microfarads)
the second part is the working voltage: 250VDC.
You can use any capacitor that is within the range. Let's say you have a capacitor that's 350VDC and fits in your in you pcb, just as long as it's over the 250V of the original it's fine.
I have put the parameters in on Mouser which I use often and you can just buy one part from them. If you click on a cap you think will work the listing will show size, type etc. This is not an electrolytic is has no direction and can be installed either way. It's polyethylene (PET)
https://www.mouser.com/c/passive-com...20dc=250%20VDC
Rob (electronic engineer)
