But if you had the 210 gal tank of water (1680 lb). and you let it absorb heat from your stove until it got to 85 degrees, then let it cool to 75 degrees, it would release 16,800 BTUs of heat.
On the other hand if you had the same 210 gal tank filled with calcium chloride PCM, and let it absorb heat from your stove until it got to 85 degrees, then let it cool to 75 degrees, it would release over 178,860 BTUs of heat.
So if Ben takes his 40 gallon tank, puts Calcium Chloride in it and hooks that to the wood stove then he could heat it up to a higher temp and get more out of it then if he had heated the 210 gallon tank of water and without killing the fish.
