Originally Posted by jeff5may
Elcam84,
Check out the Coolerado. A unit based on its design will do wonders for your shop with a cool water source and a little electricity. A straight air exchanger will not remove enough water from the air, the shop would end up 80 degF and muggy. To remove the extra water from the air, a lower temperature is needed to draw it out.
Will check it out. Since the well pump is next to the shop I'd like to use that cold water to do something before it ends up on the yard. I'd be extremely surprised if it got the temp in the shop to 80*,,maybe on a cool day in the spring or fall. Just want to be able to pull out some heat so the ac van have a little break and shorten the cool down time in the shop. It's a nice sealed insulated 20x40 metal building but 2 tons of ac takes a long time to cool it when the building and contents are over 100* including the slab...
