Old 01-07-20, 02:09 PM   #32
pinballlooking
pinballlooking's Avatar
Here is the first part I cut out the 3/8 but I used a new cam software so I could start the cut from the center of the 30MM Circle (lead in).
But it made my 30mm holes cut 28mm the kerf width is not right. That is what the torch cuts out like a blade width. Once I have that adjusted, they will be back to 30mm.
Solar Install 12.5 Kwh-
Mini Split installs -
EV Chevy Volt -
