Old 08-11-17, 09:21 AM   #6
pinballlooking
pinballlooking's Avatar
My 210 Hobart welder is here and the spool gun and argon regulator are on the way.
I also bought an adapter so I can try CO2 mig welding.
I only have an 80 cubic FT tank for welding. I needed argon for aluminum welding. I found an old set of oxygen acetylene tanks on craigslist. I called my gas supplier to make sure I did not buy a rental tank. They gave me good advice.
They wanted $100 for each tank. When I got there the oxygen tank was a rental but the acetylene tank was not a rental and it was a 150 cubic FT tank. It was old and rusty I got them down to $60 it was out of date.
I took a green meanie to knock the rust off. A can and spray paint later it did not look to bad.
I took it to the gas place this morning and the swapped it out for me with no issues. I now have a 150 tank with welding gas and I swapped my 80 welding tank for argon. One step closer to trying to weld aluminum.
Buying a 125 tank from the welding place was $229 plus the cost of the gas. The craigslist tank saved some money.
Solar Install 12.5 Kwh-
Mini Split installs -
EV Chevy Volt -
Daox (08-16-17)
