My 190 was on back order. The Hobart welders went on sale. So I called change my order to the Hobart 210 they said it would cancel out my $100 gift card. I asked to be transferred to customer service.
The 210 is also on back order until Aug3.
They let me switch to the Hobart 210 that is a better price this week and said they would transfer my $100 gift card to this order.
This will work out good the card needs to be used by Oct. I will use it on the spool gun.
It is $200 for the spool gun. This gift card will make it $100 a much better price.
The 210 can weld with 120Volts or 240 Volts
Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
