Question for any or all of you:
I have a 9.9 kW system broken into three separate "systems" on three separate inverters. The panels are 185w sharp and they go to A fronius inverter (3 strings of 8 = 24) a sunny boy (1 string of 11) and a Sharp SunVista (1 string of 19). Now, I am interested in installing an marine selector switch below the DC disconnect for the sunnyboy. When the grid works, i leave it (except to charge the batteries - see below).
So, when the grid goes down, i will disconnect from the grid and switch the sunnyboy to a sine wave inverter, which will have a charge controller and marine batteries. That, in-turn, will cause the panel to energize which will cause the two remaining inverters to begin operating. As they produce (over produce), the excess will go to a "dump", as an outlet.
I understand that there will be times when I will have to disconnect from the grid, to charge the batteries (for the long periods of time the grid doesn't go down)
Does this make sense to you?
