If you used 69 kWh with just the water heater and refridgerator running, and the refridgerator is new, I would suspect something is wrong with the refridgerator. You could very easily test this with a
killawatt. However, I would also look at lowering your water heater's temperature and insulating it with a water heater blanket.
