here are some pics from yesterdays work.. as you can see the rear end is from the golf cart and the front end is from the tride on tractor. as of right now all i am doing is cutting and dry fitting everything to make sure it fits where i need it. as soon as all if cut and fit right then i will be bolting and wielding everything together.. the look with the rear and front end together will not look like the pics i have towork on the look but basically it will still look like a tractor.. the motor in the front will be dedicated just for the cutting deck.. and the drive is in the rear just dedicated for propelling the tractor..i can't wait for this project to be up and running.. i think it will be a fun tractor to put to work.. i am also adding a horn to the tractor to drive the neighbors crazy since some of them say my projects are too quiet..
