In our last article, Xringer had the refrigerant added to the heat pump and was able to power it up and use it for the first time. In this article we’ll look at the finishing touches he had to do to button everything up. Then, we’ll go over the results he has had [...]Post from:
EcoRenovator.org
DIY Sanyo Air Source Heat Pump Install – Finishing Touches & Results
More...
