Old 02-20-17, 07:23 AM   #45
oil pan 4
Land owner
Did another one. I took my 120v air compressor which had power factor corrected, with 140uf and converted it to 240v with a different motor. I used my box of capacitors and an amp meter to power factor correct it like usual.
It ended up only needing 50uf.
It went from running a 0.2 power factor unloaded to a .96, saving almost 4 amps.
jeff5may (02-20-17)
