Old 09-21-10, 10:14 AM   #7
Sorry, I haven't responded to a bunch of posts here.
Originally Posted by Ryland
what about installing a heat pump? the attic should always be warmer then the outside temp.
That would probably work very nicely, but I'd like to start out as simple as possible for now.
Originally Posted by Piwoslaw View Post
If you have an unused chimney then go ahead and use it! It will save you the hassle and expense of running a duct between floors. Maybe make a circuit that checks temperatures and turns the fan on only when the attic is warmer than the kitchen? And Patrick is right about filtering.
Any chance of getting some insulation on that attic door?
Yeah, thats what I think I'm going to do. No filter for now. Its pretty clean up there so we'll wait to see if its a problem.
There is insulation above the door when its all closed up.
