What FordGuy said. TANSTAAFL. Hopefully your system will do a halfway decent job of pulling moisture out of the air. If not, just run a little dehumidifier. I imagine your insulation and radiant barrier has a lot to do with why your system is of adequate capacity to cool the house.
Please elaborate on the system. What SEER rating was the unit before it was modded? What kind of metering device(s) is in it? How did you determine how much refrigerant to charge the system with? The system pressures are rather close to each other for your unit. I would definitely watch the pressures after the really hot weather goes away.
