The cyberstat does store its program on its own flash memory. However, I don't know where it gets the clock/date info from. You never set that, so I assume its pulling it from the internet.
All programming is done online, so if the company goes out of business I am out of luck there.
The setpoint differential is adjustable, but not quite as fine as I would like. The options are: +/- .5F, +/- 1F, +/-2F, +/-3F. There is a big difference between +/-1F and +/-2F IMO. I had my previous thermostat set to +/- 1.5 F.
