I installed this one Takagi T-H3-DV with 0.95 energy factor
http://ecorenovator.org/forum/renova...er-heater.html
You can use 3” or 4” PVC venting.
http://www.takagi.com/products/tankl...ters/t-h3-dv-n
This works great supper efficient. They make smaller models also. Here two people can shower and run water in the bathroom at the same time.
I have had a few tankless heater. I have been using them since I was a kid. This one is the best by far that I have used.
Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
