Old 01-19-14, 08:43 AM   #5
Servicetech
Servicetech's Avatar
Originally Posted by opiesche View Post
I've switched over various rooms in my house to custom LED lighting. The kitchen alone had three 75W fluorescent fixtures, which I've replaced with custom built fixtures with LED strips in them. The light output is about the same for a total power draw of about 45W. I can only estimate, but I'd say the kitchen alone has saved me on the order of 10 bucks a month in electricity. Doing this in the other rooms should add up over time in savings
People say you can't do much with lighting, but just add up how many Wh the lighting in your house uses per month, and how much power you could conserve by cutting that in half. I've found the numbers to be significant.
30W per fixture savings x 3 fixtures = 90W. If you pay 10 cents per KWH you need to save 100KWH to save $10. 100KWH/90W savings = 1,111 hours per month. Problem is there are only 720hrs in a month.
The bigger thing that determines payback time is how much the mod costs. At retail prices the value isn't there. If you can buy the items at substantial discount then payback times are a lot shorter.
