Originally Posted by daliti
...tubes of 18 x 3 mm with tackers, 10 cm wide and 6 rows of 5 cm around outer walls.
I'm unfamiliar with this way of specifying... can you please explain what these terms mean?
Burry PE pipes ( we use the same 18 x 3) at a depth of +/- 1 m and fill it with a glycol/water mix. You install a PHE on the radiant heating and a pump on the burried captation net outside. You then will have free cooling.
This is a very interesting concept to me but I am not familiar with some of your terms...
"18x3" means what?
"...install a PHE on the radiant heating..." means what?
"free cooling" Yes, that one I understand!
