Old 07-08-19, 11:51 AM   #1
pinballlooking
pinballlooking's Avatar
Default I ordered a 4x4 CNC plasma table
I did a fair amount of research looking at build /buy a CNC table. I was close to making one but in the end buying just made more since.
I would have had more money in building one.
I have a lot to learn just in software to use it. It will be about 8 weeks before I get it. They build to order and they just had a sale.
I am getting a water table to keep smoke down and warping to a Min. It has torch height control.
I will be using my new plasma cutter on it. I will have to buy a CNC port board and a machine torch.
Delusional Designs
https://www.delusionaldesignscnc.com...ter_Table.html
I am not sure where our focus will be yet. I will be selling some stuff I cut but I would like to keep the finish and painting part to not much as this is a side business.
I am probably limited to ½” and under cuts. I will add an extension to the table to all put a 4’x8’ sheet on the table. If we like doing this we will buy a table extension to expand this table to 4’x8’ table.
Solar Install 12.5 Kwh-
Mini Split installs -
EV Chevy Volt -
pinballlooking is online now   Reply With Quote
Fordguy64 (07-09-19)
