Originally Posted by stevehull
This is where I had help from a contractor that, before this job, had never used SIPS. He was amazed at the strength, quickness of putting it up and how straight and true everything was.
Big benefits !
You may have mentioned it, but I will ask again.
How were the wall sections connected ?
Some designs use standard 2by for the spline, some use OSB strips that just slip in a slot just behind the inner and outer OSB
(no cold spot from the 2by).
