Originally Posted by stevehull
The connection of the wall to the roof is done with the aid of 2x6 trusses.
Trusses are not typically required. Panels can be side joined using several different methods, include 2by or wood I-beam. This style of construction uses a load carry center ridge beam, typically something like a 4x12 glu-lam.
The schematic that was posed on SIP construction is only one of many that are out there.
True !
I choose to add in strapping, extra point nailing, and far more construction adhesive than was called for.
Good idea in an area the is subject to high winds !
What I always want to know is how do the carpenters shoot those long screws perpendicular to the roof deck in 2 planes ?
