Here's a quick status of this little project.
got the motor, powered it up to make sure it spun the right way:
old blower before too much dissassembly
cover/gastank removed
belt cover removed, oops, thats NOT a toothed belt
somebody call the SPCA
had to dig up my puller to get the pully off
used one existing hole and poked another hole in tube to get basic position of motor, after much contemplating and holding it in different places.
pulleys line up pretty nice
Pulley attachment, will probably just hold it in place with the bolt and fudge it true and weld it on.
Original motor and electric side by side.
poked a couple holes in for the switch
Switch in place
todo:
1. dig out arc welder and weld pulley to shaft.
2. add cross supports/triangulation to motor installation
3. find a belt that reaches
