Old 09-22-15, 11:42 AM   #10
a few fleabay listings:
Ranco L27 2003 Solenoid Coil for Reversing Valve 48" Wire Leads 24VAC 50 60 Hz | eBay
Ranco Invensys L30 83 Solenoid Coil 24 VDC for V1 V12 Reversing Valve Heat Pump | eBay
6421A20003K LG Kenmore Dehumidifier Reversing Valve Solenoid Coil 030719 Sanhua | eBay
Make sure you get one that will work with your controls. AC or DC, correct voltage.
MEMPHIS91 (09-22-15)
