Let the testing begin. I ran water thru the tank for a few minutes until the out put was stable at 56 deg. I moved the WH inside the garage where the air temp is stable and wind won't cool anything off quicker. The air temp in the garage is 60.3 deg f.
I will update with results when its done.
Hv23t
