Solar hydronic floor
WilliP
Yes we have done the hydronic heated floors powered with 280 sq ft of flat plate. We live in Canada were the winter weather is harsh. Depending on the sun we have more than 50% of our space heating for the season.
I caution the use of oil for heat storage as it lends itself to environmental hazard and the system you are describing is full of net losses.
Water is hugely better at storage and heat transfer. Much safer with the addition of propylene glycol for antifreeze. (food grade). you can drink it!! if it leaks into the environment no harm!!!!
If you are interested I can provide you with first hand experience to my system that has proved itself.
Randen
